Hi all
Old Jan 19, 2013 | 10:38 PM
jWIN's Avatar
Default Hi all
Hi guys im new to this forum and wanted some pros to chime in on some of the questions I have.
My younger brother acquired a 00 s2k from my pops who some how put a big hold in the block.
Current mods are koni yellows with ground control coilovers and driveshaft shop 5.9 differential. We found a motor at a local shop for $2, 500. We should have around around $4, 500 left for supercharger the first month . My question is would that be enough for a good supercharger? In no rush and wont be taking any short cuts. looking for around 400whp . Can someone please list me parts I will be needing like injectors/ems....ect. thanks in advance =]
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
Old Jan 19, 2013 | 11:01 PM
watch0bak's Avatar
$4500 is going to be tight.
Lets say you get lucky and find a complete kit for $2500. Then there's ~$1k+ for EMS, $300-400 for injectors, ~$100-$150 for fuel pump, ~$100 for map sensor and then $500+ for dyno tune. Assuming that there wont be ANY other issues and the kit you pick up is 100% complete (which rarely happens, especially at that low price), that might be BARELY enough, but at 400, you would need clutch since stock wont hold.
I am not saying it wont be possible, but that budget doesn't give you any room for errors/issues that may come up and even if everything works out, IMO is not going to be enough. Good luck!
Old Jan 19, 2013 | 11:04 PM
jWIN's Avatar
Thanks for the reply. The $4, 500 is for the supercharger only. Ems/injectors/tune/clutch....ect will be on a different budget. I just need a list of what I need to I can add everthing up. Can someone please point in in the right direction as in what brand supercharger.
Old Jan 19, 2013 | 11:17 PM
watch0bak's Avatar
If CARB isn't an issue for you, I'd think its best to go with SOS. I think you will be fine with any of the kits (SOS, Comptech, or Vortech) as long as you don't get NOVI1000 with a comptech (which will make it hard to hit 400).
You would need:
EMS (KPRO, AEM, Flashpro(06+) or Haltech)
Injectors (prob would wanna get 1000cc)
Fuel pump (I've used fb340 with good results)
Map sensor (I've used SOS)
Clutch (Most stage 2 should be good enough for your goal)
Tune.. depends on where you are located
Old Jan 19, 2013 | 11:23 PM
jWIN's Avatar
Thanks again for the fast response I wilk go with the 1000cc injectors and aem along with the vortech. Would vortech be the best place to buy the kit?
Old Jan 19, 2013 | 11:42 PM
Reapur's Avatar
Buy the kit from SCIENCE OF SPEED and make sure you you pick the Novi 1200 blower
Old Jan 19, 2013 | 11:51 PM
jWIN's Avatar
Was just on sos site. But I dont see the prices.
Old Jan 20, 2013 | 12:03 AM
watch0bak's Avatar
http://www.scienceofspeed.com/produc..._Supercharger/
Pick your year and scroll all the way down. You will see the prices!
Old Jan 20, 2013 | 12:06 AM
watch0bak's Avatar
Or in your case, you would probably want stage 2.. and I am assuming you have 00-05 since you want to use AEM:
http://www.scienceofspeed.com/produc...systems_00-05/
Old Jan 20, 2013 | 12:43 AM
jWIN's Avatar
Sweet alright if I go with that stage 2 what eles would I need? I will sell those 650cc injectors and get the 1000cc
