high idle
Old Jun 15, 2007 | 05:42 AM
dragtek's Avatar
Default high idle
i just got my car back...but i have yet to tune it. however, the idle is kinda high...between 2-3k at times. i was told that i can fix that when i tune the ems. is that true??? also, i changed the TB too could that have an affect?? thanks in advance
Old Jun 15, 2007 | 10:18 AM
dragtek's Avatar
anyone??
Old Jun 15, 2007 | 10:23 AM
mase1's Avatar
well first give us more information.
did the car start idling high after you put a throttle body on the car, or did it happen when you installed the aem. perhaps you did it at the same time, in that case, you should go ahead and check for vac leaks and lower the target idle in the aem software.
Old Jun 15, 2007 | 10:55 AM
dragtek's Avatar
i installed them both at the same time. I have to tune the car so im sure that they will lower the target idle for me. where might i check for vac leaks??? thanks in advance
Old Jun 15, 2007 | 08:37 PM
Spec_Ops2087's Avatar
If its not tuned then thats why. The basemap probably idles pretty high to ensure it works on all s2k engines.
Get it tuned, it'll be normal again.
Old Jun 16, 2007 | 06:40 AM
dragtek's Avatar
thanks 4 the info
biohazarde
May 1, 2014 03:49 PM
Shftat9k
Jan 10, 2012 08:42 AM
Suits
Apr 21, 2011 05:47 AM
djap1
Mar 29, 2007 05:03 AM
jbotstein1
Sep 15, 2006 08:27 PM
