hondata IMG worth it on turbosetup?
Old Nov 11, 2008 | 06:52 PM
  #21
EK9MAX's Avatar
Originally Posted by S2oooNvegas,Nov 10 2008, 08:34 PM
Coo, youll be OK then. mini me isnt bad to install, from what ive heard.
No loctite. the thing is, the manifold walks around as it expands and contracts. so after 2-3 hours run time, or 150 miles, the nuts will all go at least another half turn, to hold torque of 20 ft lbs. make sure all the supports are in place also, many miss that. Ive done both ways, large flat washers 2-3mm thick, under block side of bracket, and or enlarging the holes at manifold side of bracket.
Also use a medium coat of this...
that rules. i first port match mine, cause they always overhang the ports, then use gasgacinch, and ive never had an issue. every single one has been half to 3/4 turn loose within 2 days.
I have then rechecked the torque again at 500 miles, perfect. not loose at all.
seems like a lot of work to get at those botls again..... doesn' the alternator and tensioner have to come off to get at all of them???
Old Nov 11, 2008 | 07:00 PM
  #22
jdnissanz's Avatar
I got it installed by my tuner I don't know the benefits, but my dyno will be next week hopefully yields better temps.
James D.
Old Nov 11, 2008 | 08:29 PM
  #23
Slows2k's Avatar
Unless I absolutely had to remove the intake manifold or cylinder head, I wouldn't bother.
My own time vs benefit analysis says I'd rather be than removing a perfectly good intake gasket that isn't leaking.
Old Nov 11, 2008 | 10:14 PM
  #24
S2oooNvegas's Avatar
nah, bad ass 1/4 drive swivel 12mm, and 10 and 12 inch extensions, your good to go. I can retorque in about 15 mins. just being patient, have to tape the socket to the ext, so as not to drop it on all the bottom ones.
Ive always torqued them to 20 lb ft also. I dont know about other guys, but thats where i set them. no problemos.
Old Nov 12, 2008 | 08:04 AM
  #25
Voodoo_S2K's Avatar
I know of one person that was F/I that melted one.
JusS2k
Jun 13, 2011 03:59 PM
badmonkey
Aug 13, 2008 05:53 PM
one_slows2k
Nov 19, 2007 06:08 PM
flexer
Aug 20, 2006 07:07 AM
Gernby
May 29, 2002 12:35 PM
