How to drill crank pulley for Vortech sc use?
Old 12-09-2009, 10:27 AM
Former Sponsor
Moddiction's Avatar
Thumbs up How to drill crank pulley for Vortech sc use?
The pulley that came with the Vortech SC kit that was attached to the modified vortech collar part was chipped and broken during shipping.
I just bought another oem crank pulley but it needs to be drilled so I can attach the second part of the vortech pulley to it.
Does anyone know how it should be drilled? I am assuming I can just fit the collar over the stock pulley and then drill through the holes but what size drill bit and how deep etc? Do I have to use a tap or anything?
Any info would be appreciated. Thanks.
Old 12-09-2009, 10:39 AM
Slows2k's Avatar
It will have to be drilled with a drill press, and tapped. If you don't have a drill press do not try to do it by hand.
Old 12-09-2009, 10:41 AM
itlynstalyn's Avatar
I believe you're going to need to send that in to Vortech.
Old 12-09-2009, 11:07 AM
drhess06259's Avatar
I did mine by hand just had the pully in a vice and a clamps holding it all together.
Old 12-09-2009, 11:48 AM
Former Sponsor
Moddiction's Avatar
Anyone know the bit size and tap needed?
Old 12-09-2009, 01:31 PM
Former Sponsor
Moddiction's Avatar
Vortech will not drill it for me only sell me the new one for $370 or whatever which I don't want to do. Sure seems like it would just be a simple drilling. I guess I will find a machine shop to do it to be safe but need to know the drill bit size, depth to trill and then what tap is needed.
Old 12-09-2009, 02:16 PM
SgtB's Avatar
If it's not perfectly centered you may run into problems.
Old 12-09-2009, 02:27 PM
take the bolts your going to put in it into the machine shop they will know what size bit and tap to use. if that is the route your going.
Old 12-09-2009, 02:32 PM
Former Sponsor
Moddiction's Avatar
True haha tired didn't think of that lol.
You ever have any issues doing it or using it afterwards?
Old 12-09-2009, 02:45 PM
I only had the vortech kit a short period of time but no i didn't have any issues. I am turboed now with a lightweight pulley
Quick Reply: How to drill crank pulley for Vortech sc use?
