How-to Inline pump Install
Old Feb 4, 2010 | 06:54 AM
siadam's Avatar
Default How-to Inline pump Install
I just picked myself up a Bosch inline pump to supplement my fuel needs w/the walbro.
I have a stock rail, but an AEM FPR.
What is the install like?
Anyone else already done it? Any tips/tricks/advice?
Thanks!!
Old Feb 4, 2010 | 06:59 AM
boostedf22c's Avatar
You'll probably have to get a new FPR. I'm not sure if you have the AEM one that mounts on the rail, if you do, once I put my Bosch 044 pump in, it couldn't bypass quick enough and saw 100+psi just priming the system. Replace that and all was good. Other than that, it's straight forward.
Old Feb 4, 2010 | 07:02 AM
siadam's Avatar
Thats exactly what I have, just picked it up a few weeks ago.
What are my other options?
Did you have to re-run line from the rear up front, if so what size?
Old Feb 4, 2010 | 07:34 AM
s2000442's Avatar
Replace it with what fuel pressure regulator?
Old Feb 4, 2010 | 07:54 AM
freshs2k's Avatar
I'll be doing this soon also. I want to know what will need to be changed and or thrown out and replace. Everything is stock except injectors and fuel pump.
Old Feb 4, 2010 | 09:09 AM
Irishflame27's Avatar
im curious about this as well, i would love to see how people have done theres
Old Feb 4, 2010 | 09:16 AM
s2000442's Avatar
^^love that sig! May need to copy that from you when I get the turbo done
Old Feb 4, 2010 | 09:45 AM
ZLFAB's Avatar
i have a walbro in tank and another walbro inline on the rubber feed line and mounted it to the frame rail. i made 662 on a stock fpr and lines.
Old Feb 4, 2010 | 10:01 AM
siadam's Avatar
Good info.
My question is, how do I adapt the inline pump fittings to attach to the stock lines?
Old Feb 4, 2010 | 10:18 AM
Shftat9k's Avatar
Did you have to run a new line from the out of tank walbro or were the stock lines just modified. I like this a lot better then the 044 since that thing is super loud I hear.
Do you have pictures on what this set up looks like by chance?
