How to maximize the Vortech Supercharger
Originally Posted by Sideways,Jun 20 2008, 03:07 AM
Thanks.
IATs on a warm 80 degree Spring day ranged up to 121 degrees f. It's running nice and cool with no hint of knock using pump gas.
I had in the max 65 degree celsius and in the min 36 degree celsius, but on water injection (which lowers IAT to about 7-8 degree celsius for the moment) and an additional air inlet through the fake fog light.
Now with the water pump for the aftercooler being defect I see 75 degree celsius max and 52 min w/o water injection, 39 w water injection @ 5400 rpm. So especially running in idle and w/o wind cooling it the IAT goes up like hell.
Wasn't it a 3% power loss every 10 degree fahrenheit more or so?
Will work getting better IAT numbers once the pump is ok again.
Andreas
Originally Posted by A4XRBJ1,Jun 21 2008, 08:16 AM
Wow, that's only 49 degrees celsius on a hot almost 27 degree celsius day.
the maximum IAT number that i have ever seen is 80 degrees ( 176 F ) while revving all gears up to 270km/h.
do you thing that i might have a defected water pump for the aftercooler or is just because of the 17+psi that the s/c produces?
Originally Posted by yiannakos,Jun 25 2008, 01:06 AM
this month that temps reach 30 degrees celsius ( 86 F ) during noon , in traffic and without passing 4500rpm i see 55 degrees celsius. (131 F )
Well, my problem is fixed. The pump was running out of water, as from the triangular box that is mounted on the right front it was (is) loosing the water. So I think two things happened:
- the aftercooler lost all water, therefor high temperatures
- the pump was running dry, which it didn't like at all
On top it burnt the fuse, which we found out after installing the new one. Now I have a cool aftercooler again, but I still loose a lot of water from the triangular thing.
How did you guys do the installment on this plastic thing, we can screw enough to seal it?
Any hints how to fix it, for now I can get new water in each other day but for longer?
Andreas
Originally Posted by Sideways,Jun 27 2008, 05:47 AM
Several layers of teflon tape and tighten them down.
Andreas
Originally Posted by A4XRBJ1,Jun 26 2008, 11:16 PM
you will hear your water pump. Easy to check if it works. Check also inside the aftercooler how the water is circulating!
Andreas
Andreas
i hope that i am not off topic
since my problem is what we are talking about ......... over spinning
Originally Posted by Sideways,Apr 23 2008, 09:36 AM
Goodies include a 70mm BDL throttle body, GM 3 bar MAP sensor, modified intake manifold, 4 inch cold air intake...
Originally Posted by d-j,Jun 30 2008, 02:17 PM
Can you estimate any gains from a larger TB & ported IM?
At higher boost levels the gains may be greater. That said, I went from 64mm to 70mm and didn't feel anything except a difficult to modulate pedal.
