I went to Church
Old Aug 12, 2007 | 10:09 AM
  #31
AirborneS2K's Avatar
Originally Posted by Sideways,Aug 12 2007, 04:43 AM
It is not just polishing. It includes drilling and grinding.
You remove the pounds by removing unnecessary metal. Notice where the block off plate is located at the top of the picture. Notice to the left of the plate you can see through.
Factory manifolds are two inches of aluminum at that point. I removed where you can see through.
BOTTOM VIEW
Several runners and bosses have been removed. Unnecessary material has been ground away over the entire manifold.
BOTTOM VIEW One support and boss removed on runner one, two supports on runner two were removed.
And what is this Rutherford BS doing in my post. He is basically stock. At least it runs that way.
Good deal...remind me, what is the point of the block off plate?
Old Aug 12, 2007 | 10:28 AM
  #32
stuntman21133's Avatar
get rid of SAI (secondary air injection) That has to be one of the sexiest manifolds I have seen.
Old Aug 12, 2007 | 11:36 AM
  #33
stena's Avatar
Wow thats some serious weight off.
I weighted my OEM with the EGR on and the CF on and the CF one is maybe 1/3 of the weight of the OEM one...
if i remember right its like 11lbs compared to 4.5lbs?
But i wouldnt go that far as saying that you can take 4 off with grinding and the other stuff. The EGR takes away the most...
anyway great IM and thats Chromed out probably?
Old Aug 12, 2007 | 12:24 PM
  #34
Sideways's Avatar
[QUOTE=stena,Aug 12 2007, 12:36 PM]Wow thats some serious weight off.
Old Aug 12, 2007 | 12:37 PM
  #35
Asura's Avatar
When Mr. B.S. gets off the fence between NA and FI, we should be very very worried.
Especially if his 'other' projects are a benchmark for the dark recesses from which his thought processes materialize. Basically stock turns into almost stock
Old Aug 12, 2007 | 05:52 PM
  #36
stena's Avatar
Why didnt you cut off the EGR Holder in the first place?You dont use it anyway.
Anyway here is the Comparo of the two i did..
Intake Pleanum Difference..
OEM
CF
We will see what power it makes in a week or so i think.
stefce
Old Aug 12, 2007 | 06:15 PM
  #37
Asura's Avatar
Probably so the car can pass CA smog visual inspection when the time comes.
Old Aug 12, 2007 | 06:50 PM
  #38
Spec_Ops2087's Avatar
I somehow think the EGR is the least of the worries when / if it comes to passes emission / inspection
Old Aug 12, 2007 | 08:00 PM
  #39
2QYK4U's Avatar
Nice gains Phil! Up for some freeway rolls?
Old Aug 13, 2007 | 02:42 PM
  #40
Sideways's Avatar
[QUOTE=2QYK4U,Aug 12 2007, 09:00 PM]Nice gains Phil!
