IAT Sensor Connector P/N
i need to replace the IAT connector (on the wire harness side). any one know the P/N for the connector, pigtail & termial joint. the service manual refers it to the "2P" IAT sensor connector.
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
thanks and I would love to know the part number - my parts guy must be lazy - he said Honda didnt sell the engine connectors seperate.
however i found a guy online from a honda dealer (autofair) that sells the iat sensor with the connector and pigtail ($40) for the RSX which is the same part numbers as a the S.
I guessed at the Honda part number (04321-S5A-305) and order a pack. it was "almost" the right connector - every thing was a match including the pins except for the molded "ears" in the external housing of the connector which could be grounded off to make it work. the sensor would still match up to the locking clip of the connector. but for $40 bucks i can get the sensor, connector & pigtail.
so i ended just buying a new sensor, patching up my connector - which got chewed up a little in the acc. drive belt... everything is good...
