IAT Sensor Connector P/N
Old May 29, 2013 | 03:32 PM
thesilverbullet's Avatar
Default IAT Sensor Connector P/N
i need to replace the IAT connector (on the wire harness side). any one know the P/N for the connector, pigtail & termial joint. the service manual refers it to the "2P" IAT sensor connector.
Old May 29, 2013 | 06:24 PM
Ahnold's Avatar
Not sure that you can get OEM connectors, pins, etc..
I would love to know if they are available from somewhere though
Old May 30, 2013 | 02:54 AM
donaldmejr's Avatar
My Honda dealership gave me a part number for a connector one time...then i went online typed in the part number and found it. try a dealership?
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
Old May 31, 2013 | 04:56 PM
thanks and I would love to know the part number - my parts guy must be lazy - he said Honda didnt sell the engine connectors seperate.
however i found a guy online from a honda dealer (autofair) that sells the iat sensor with the connector and pigtail ($40) for the RSX which is the same part numbers as a the S.
I guessed at the Honda part number (04321-S5A-305) and order a pack. it was "almost" the right connector - every thing was a match including the pins except for the molded "ears" in the external housing of the connector which could be grounded off to make it work. the sensor would still match up to the locking clip of the connector. but for $40 bucks i can get the sensor, connector & pigtail.
so i ended just buying a new sensor, patching up my connector - which got chewed up a little in the acc. drive belt... everything is good...
thesilverbullet
Jul 21, 2015 02:52 PM
salmo
Jun 30, 2012 10:36 AM
mzm70
Nov 23, 2009 11:20 PM
