id1000 injectors need spacers?
Originally Posted by teamvalorracing,Jun 29 2010, 01:25 PM
my ID 1000's came with 3 little washers that i put on over the rail mounting studs before the rail. i just left the factory manifold grommets in and put the injectors ontop. no mods needed. the id s2000 kit came with the injectors, pigtails to be assembled, and 3 washers. thats all you need.
*dont know if its diff for AP1/AP2
http://www.adrenalinrushllc.com/store/down...nstructions.pdf
"The S2000 injectors come assembled with the necessary modifications. The supplied lower cushion will press against the factory cushion for a tight seal. Install supplied 8mm washers under the mounting studs for the fuel rail (between the studs and the intake manifold)."
For some reason to me it doesnt make sense to have both grommets (cushions) pressed against each other, but if thats what everyone does please let me know. Thanks!
Yes both seals "press" against eachother to create a seal. Doesnt seem like the best setup but it works and everyone else here is running it like this.
Simply take your oem injectors out, and replace with the ID injectors except put 1 small washer under each mounting post for the fuel rail.
My kit is older than this thread and the cushions it came with and they pretty much disintegrated. The oem ones that sit below them are fine. Anyone know where I can find some replacements or even better would be an one piece solution instead of double stacking them
Email sales@t1racedevelopment.com with your billing/shipping address and we can get them out today.
