Impeller Speed Calculator
Old May 20, 2011 | 03:49 AM
Sideways's Avatar
Default Impeller Speed Calculator
Vortech has an impeller speed calculator that has the 3.6 step up ratio and allows you to vary pulley and engine rpm.
The first listing on their calculator is for use with jack shafts. This allows a variable to be entered converting to a new answer. http://www.vortechsuperchargers.com/...d%20Calculator
By entering the Vortech ratio 3.6 at the first jack shaft cog pulley teeth and the Novi ratio 3.45 as the second jack shaft cog pulley teeth it should give you proper results.
5.45 inch crank pulley
9000 rpm
3.6
3.45
3.2 inch pulley
53029 rpm impeller speed.
Anyone want to confirm this works out correctly?
Old May 25, 2011 | 03:11 AM
RAIN H8R's Avatar
With my formula its a little off from what you have. My spreadsheet does the math for me.
3.45in Step up
5.45in Crank
3.20in blower
52,882 @ 9,000 RPM
bruthaboost
Nov 23, 2017 09:26 PM
july7543
Jul 17, 2010 12:55 PM
ILOVEMYAP2
Jun 30, 2009 11:10 AM
johninator
Sep 17, 2005 03:03 PM
