Injector driver
Old Sep 30, 2008 | 07:23 AM
snakeeater's Avatar
Sorry, I didn't see that you already had a resistor box. That adds the resistance back into the stock driver circuit that the P&H injectors are lacking. It just doesn't have true Peak & Hold current limiting curve. It still has the OEM saturated coil-type driver's steady, flat current characteristic.
I assume you have AEM EMS or some piggyback, since you have 680cc injectors. But whatever you have should have some provision for reading and/or logging wideband O2 (A/F ratio). If you can get that reading at several load (horsepower) points (especially the endpoints), then you could tell if you need to retune or not. A/F ratio should always be between about 15:1 (@ no load, like idle) and 11.5 or 12:1 (@ max boost).
If you still have the stock ECU with a piggyback, the stock adaptive trims might handle any small difference in flow between resistor box and P&H driver. I have no experience with EMS, so I don't know how well it's adaptive trims "learn". I have heard the "self-tuning" is limited in it's useful ability to adaptively trim to the desired A/F ratio you set for it.
godmachine
Houstook Swap Meet
Jan 29, 2009 01:51 AM
TheCarGuy2021
Apr 30, 2008 05:32 AM
Sub-Zero
Oct 15, 2006 08:37 AM
fperra
Jun 11, 2005 06:37 AM
