InlinePRO Intake Manifold
Originally Posted by BerlinaMOBster,Feb 9 2010, 12:33 PM
just went from 6 to midnight... nice setup there! do you have a build thread?
Sorry for off topic
Sorry for off topic
He's almost finished with the parts, then everything is going to Swaintech for coating.
On topic: the intake manifold looks great. I've already got the IP fuelrail and a 70mm Skunk2 TB. I think it's gonna kick some serious ass
I've been looking around for the Hypertune for years but either no response or couldn't get it.
Originally Posted by wadzii,Feb 9 2010, 04:44 AM
the only one loosing respect is hypertune.. coming on a forum like a 2 yr old crying that something im sure he has never seen in person is a copy.
But If someone did rip off his design... (straight up used his mani for a cast mold) I could see where he would be pissd, and lost respect for calling it there design and marketing it as a "new" manifold. But heh do your thing. I mean shit Taiwan doesnt even recognize US patent laws and directly copies whatever they feel they can make a profit on.
Just my .02
Honestly i could care less...
It does look like a very nice piece, and i am intrested in seeing the forced induction dyno results.
First off, saying that negative pressure doesn’t exist is like saying negative numbers don’t exist, it’s just not true. If you are using a relative pressure reference frame you do have negative pressure, in fact most people see negative pressure daily when driving their turboed/ supercharged cars.
And secondly for car A you are ignoring atmospheric pressure. I think you are confusing yourself by using the absolute pressure scale. If atmospheric pressure is 14.7 psi and cylinder pressure is 4 psi, you still have a 10psi pressure differential. You may have a .7 psi pressure differential if you take a look at very small control volume, but this is irrelevant to the overall system.
[QUOTE]And lastly a velocity stack, depending on geometry can actually hurt a forced induction cars mass flow. There are 2 reasons for this, but they both equate to 1 parameter called K= pressure loss due to entrance effect. As you can see in the diagram the velocity stack config has the highest loss factor of all the entrance effects. This is because pressure loss varies linearly with air density and as the square of velocity. So as a turbo car shoves more air into the manifold, air density increases as well as air velocity, leading to higher pressure drops due to K. For forced induction a well rounded inlet would make more sense.
The scale isn't significantly different but look at the colors, and my drawing was a quick 5 minute example. A true velocity stack with proper taper and variable radius would be even better.
Either way it's certainly a lot better than putting up irrelevant diagrams and claiming the one with a "velocity stack" is the worst.
Originally Posted by BerlinaMOBster,Feb 9 2010, 06:06 AM
No i do not agree with that statement at all. He simply is just trying to get it out there that someone stole his design. Weather this is true or not who knows... but from what i have read Hypertune has no US patents on there manifold designs. If thats true than lawyers cant do didly, and ranting on public forums might be the next best alternative lol.
Just my .02
for yet another Product for the S2000
if you copied it and are passing it off as your own.
Just my .02
The main thing that I was saying is that the way the manifold in the pic that was posed of the round plenum with v-stacks sticking up 2/3 of the way is worthless. the outer wall of the plenum is so close to the opening of the stack that it would cause issues and there is no reason what so ever for the stack to be that high off the floor.
