inlinepro TCT
Old Jul 7, 2010 | 07:03 PM
  #41
SHEPSS2K's Avatar
I had pm'd ya before. if your running the 3mm headgasket he had said it gets rid of the slack in the chain that happens over time so its not a issue and IP tensioner isnt needed . So im assuming that this tensioner would break chain or the possibility too and inline doesnt wanna have motors break and get bad p.r. .
I see red star motoring runs this now in there high hp s2k. im assuming something is done to make this better.
Old Jul 28, 2010 | 08:05 PM
  #42
S2oooNvegas's Avatar
So i guess i have the only real solution to this problem, STILL.
Which makes me feel good.
I have alot on my plate and so i havent really "offered" the solution.
Most of what i have found, is already known. but......
It seems the number 1 problem is oil volume to the setup.
Over 2 years ago i began modifying the body of the tensioner by drilling the oil inlet port. I doubled its size, to .060" (thou of an inch.)
I simply retension the springs (stretch) and reassemble. I then have the person switch from shitty mobil1, which is what almost all the problem cars have, to valvoline 10/40.
Thus far i have not had one tensioner issue reoccur. And i have probably 25 out there.
There is an oil jet bolt in the end of the tensioner, it decides what volume of oil gets to the worm gear. So the only thing that could happen, is you overdrill the inlet port on the side of the tensioner, and you will overfill the cap on the tensioner and notice a leak. You cant possibly overpressurize the tensioner and snap the chain with my method.
I dont know what IP did to the tensioner, but a monkey could figure it out in 3 mins if they just disassemble it. I doubt they can patent any sort of modification to an existing design, and charging a ton of money for a tensioner thats less capable than a factory unit is just asking for trouble.
Thats my 2 cents. Need any tensioner help, PM me.
Later dave
Old Jul 28, 2010 | 08:53 PM
  #43
Muscle Cars Blow's Avatar
So Does a 3mm head gasket add slack to the timing chaing. Thus causing all these problems? Or are the two not related? My friend is looking at going turbo'ed and doesn't wanna blow his motor up cause his timing chain wore out cause of a 3mm gasket.
Old Jul 28, 2010 | 09:45 PM
  #44
juntuned's Avatar
Ya, I suggest you tell your friend to stay NA. We wouldn't want his chain to "wear out"!!!!
Think about it, would adding a spacer create slack? Or tighten the chain? Tighten it of course.
I would assume with a 3mm HG you would be BETTER off with an oem TCT not worse. It's when you remove material (not add) like head milling, that creates slack in the chain which is where you run into problems.
Old Jul 28, 2010 | 09:50 PM
  #45
godmachine's Avatar
I went ahead and told T1 to install this TCT onto the car . I hope it cures all my TCT issues but if it blows my motor I dont mind having inlinepro replacing it for free
Old Jul 29, 2010 | 12:12 AM
  #46
AlexS2200's Avatar
From: 13851 A Better Way #11D, Garden Grove, CA 92843
Later dave
That is great info
Old Jul 29, 2010 | 07:23 AM
  #47
Was asking for my friend, no need to be banging your head on a wall but he told me 3mm was thinner then the stock head gasket. Which would in fact create slack. Now if 3mm is thicker then putting this in would of course add to the tension. Which to me doesn't make sense to put a 3mm gasket and increase the combustion chamber size when your going to add FI to the motor. Seeing as most people reduce combustion chamber size at the time of going FI usually with Low Compression Pistioins. But hey I'm a domestic guy and maybe things are done differently over here.
Old Jul 29, 2010 | 08:00 AM
  #48
NaturalAspirations's Avatar
Low compression pistons increase the open area in a combustion chamber ( less dome less volume) this makes preignition less likely. The thicker HG increases cylinder volume ( specificaly reducing the quench area ) while running the factory high comp pistons. I think you just got confused.
Old Jul 29, 2010 | 08:19 AM
  #49
More then likely I'm confused. So 3mm gasket with turbo is good. E will be running stock lower end with inline pro kit. He's only looking for 350-400 RWHP. Nothing crazy. He just wants a decent DD that won't blow up all day. And I'm soon to buy and s2k and do the same. So we want reliability along with a turbo. Want to have all ducks in a row before we nuke a perfectly good motor.
Old Jul 29, 2010 | 12:49 PM
  #50
siadam's Avatar
If you guys care that much call them and ask them.
There # is 703.455.5805
Not a huge mystery.
