Inlinepro Tubular Manifold
Originally Posted by blue03s2k,Oct 3 2006, 10:38 AM
and this is the reason at 8psi lovefab gets est: 350 while 8psi inline gets est: 310..... but you COMPENSATE for the lower compression by upping the boost to achieve the same power output...
so there's nothing wrong with my post...
When I up my boost to 10 psi on the stock compression, I'll be around 450+ whp.
Originally Posted by Spoolin,Oct 3 2006, 11:28 AM
Actually though, my Lovefab manifold setup is putting down 332 whp on 6 psi with a 60-1 turbo, stock compression and a very very conservative tune.
you are still missing my whole point..... and refering to the post that i quoted....
looks like a good setup!
Thanks for the PM YA.
The thing I like about Inline Pro is they have so many options and most of them seem to have been tested fairly well be for they were released. They don't push for you to purchase unecessary items to get to the power you want. If you do want something they can help you get.
That being said, I sure some of the other Turbo Manufactuers on this board have good products too, but I believe some may not have kept up on the quality control of there products enough. This would have kept some of the issues that have arose with there kits from happening.
Plus the manufacturer wouldn't look so bad in the end when there probally not. All it takes is a few mistakes and everyone comes down on you.
I understand when you make changes to a car shit will happen, but you don't want it to happen to often.
Thanks for everyones input on this thread.
Originally Posted by ya@inlinepro,Oct 3 2006, 11:53 AM
i definately want to see your car at 450rwhp at 10psi. definately post pics and dyno numbers. also please show what dyno as well.
If you do the math, it is very easy to get the numbers I am looking for. On this dyno, stock, I dyno'ed 187 whp and after the turbo at 6 psi and tuned fat and low timing I got 332 whp(BTW, this was achieved on a very hot and humid day, 92 degrees). That's a difference of 145 whp, now divide that by 6 (psi) and you get 24.2 whp per psi. Now add 4 more psi (24.2x4=96.8) and make the timing a little less conservative and A/F leaner than 11:1 and more like 11.9:1 and it should get me right where I claim; 450+ whp.
Originally Posted by ya@inlinepro,Oct 2 2006, 10:28 PM
Just out of curiousity, has anyone run their other kits at the track yet? I'm just curious as to what times they put up. PRS2k was running 12's with his setup consistantly with the 350rwhp at 10psi.
Has anyone else ran their other setups?
Is that ferrari enough??
Originally Posted by AROD,Oct 3 2006, 09:42 AM
I ran 11.6 @ 127mph with a horrible 60ft on the off the shelf inline pro turbo kit....................
