Installing inline pro 3mm head gasket on 2005 s200
I installed inline pro 3mm head gasket on my 2005 s2000 (f22) but the timing chain has too much tension and I did not put in the timing chain tensioner on yet. Do I need a longer timing chain? What am I doing wrong? I there any other way to adjust the timing chain tension? How do I solve this problem. Thanks in advance.
Thanks for the responses. I reclocked the gear. I spoke with someone from inline pro today and they said the additional tension caused by the 3mm head gasket is fine. I should be done putting on the turbo by friday. I will let you guys know if the car runs okay. I will break in the engine for 500 miles and then do a oil change because the timing chain guide will wear done a little.
stucks2k
Oct 7, 2010 06:01 PM
NFRTurboTerror
Feb 6, 2007 05:45 AM
