IP stage 2 progress and help thread
Old Oct 3, 2010 | 05:30 PM
  #131
dsddcd's Avatar
Originally Posted by D1sclaimer,Oct 3 2010, 08:23 PM
No parts store could get me either plug this weekend. I had a set of autolite (long story why I have them) sitting around so I gapped them and tried them out. Same issue with cutting in and out.
I decided to take about a degree of timing out for positive MAP pressure and richen it a tad. That cured it. No more cutting in and out at all.
I did have it cut out pretty bad later this night, but it was the coldest I've driven the car yet and before it was getting really close to boost cut. I'm guessing it was boost cut and wasn't logging as I was driving home.
Have you set up your Boost control feedback yet? This will help keep you away from the boost cut.
As for the plugs what are you running? I have found that 0.025" seems to be the sweet spot.
You ready to try out my Ignition system?
Old Oct 3, 2010 | 05:52 PM
  #132
D1sclaimer's Avatar
I have it set up for boost by speed, but haven't looked at boost feedback yet. I figure I should now since thats an issue.
They are Autolite 3922 plugs. I gapped them at .022 since the .024 was cutting out. They crosslisted with the NGK 4644 plugs (stock heat range, copper, with resistor).
I think over winter I will also look into CDI ignitions. I think your system uses LS1 parts right?
Do you think it was cutting out because the ignition or because it was a little too aggressive? Since I added fuel and it still doesn't cut out, I would think it was just a little too aggressive.
Old Mar 11, 2011 | 01:25 PM
  #133
D1sclaimer's Avatar
Almost done with the ignition. I hid the ignition box under the cowl next to the cabin filter. It seemed to be a good spot out of the heat and covered so it wont get wet. Instead of splicing into the factory harness, I bought an AEM patch harness for the s2000 and spliced into that. The AEM harness is a lot better quality than my Boomslang VAFC harness was so thumbs up to them. With the patch harness, I can change back to the stock coils in about 10 minutes by removing it and changing the settings in the EMS back to the stock coils.
A word of advise if you switch to a CDI ignition. I skipped the part in the manual where it said to verify timing after you change the dwell settings in the AEM. By switching to the CDI ignition, timing was retarded around 11 degrees so far I've found. It was hard to start and sounded like a WRX when it ran, but when a friend suggested that timing was thrown off, I used the "verify timing" procedure in the EMS to advance timing about 11 degrees to pull similar vacuum that it pulled last year. No more WRX sound. I'm gonna hook up a spark plug wire to the coil and timing light up to it tonight to verify it is on. With the COP CDI coils, you can't get a signal for the timing light like you can the stock coils. You need to put a spark plug wire in between the plug and coil and hook up the pickup off the wire.
Getting tuned at Full Blown on the 26th. I'll be driving 7 hours on this new ignition setup and taking with my stock coils just in case.
Old Mar 12, 2011 | 08:21 AM
  #134
DFWs2k's Avatar
can't wait to see new numbers, you have the pcv plumbed into the intake mani?
ever get manifold coated?
Old Mar 12, 2011 | 12:35 PM
  #135
D1sclaimer's Avatar
Currently, the PCV is straight to the intake manifold. I was contemplating doing what neeman77 said he did and run a hose from the PCV under the intake manifold with a breather and then cap off the port on the intake manifold.
Manifold is not coated. Before summer hits, I was planning on getting a heat shield made.
Old Mar 12, 2011 | 01:02 PM
  #136
DFWs2k's Avatar
Ah, my underhood heat was ridiculous.until I had manifold coated and hood cut. Ill be taking everything off soon to see how it is holding up. I got a mase heatshield to put on too.
Old Mar 12, 2011 | 06:41 PM
  #137
D1sclaimer's Avatar
Yeah, I have a turbo blanket, down pipe wrapped, and have most stuff near there wrapped so it doesn't melt or catch on fire. My underhood temps are pretty crazy too.
Old Mar 12, 2011 | 07:43 PM
  #138
Spoolin's Avatar
Why didnt you just go with the AEM twin fire ignotion with the AEM pencil coils?
Old Mar 12, 2011 | 08:11 PM
  #139
D1sclaimer's Avatar
http://www.honda-tech.com/showthread.php?t=2413830
http://www.honda-tech.com/showthread.php?t=2590907
http://forum.aempower.com/forum/inde...c,19383.0.html
http://forum.miata.net/vb/showthread.php?t=207837
http://www.honda-tech.com/showthread.php?t=2849853
http://forum.aempower.com/forum/inde...c,27290.0.html
These are just a handful of the AEM Twin Fire threads.
Old Mar 12, 2011 | 09:13 PM
  #140
Spoolin's Avatar
Hasnt AEM already fixed all the problems?
One guy here http://www.honda-tech.com/showthread.php?t=2849853 said to use the M&W pro14 box with the Honda OEM coils. Will that work instead of the AEM coils? That would be sweet if we could just get the M&W pro14 box and just hook it up to run with our OEM coils.
