ITB Turbo Part 2
Old 06-29-2007, 05:10 AM
  #101
S2000_Europe's Avatar
I had the single and the dual, and I prefer the dual, as Mr TurboITBAquamistZ06 said the Dual has a deep sound and the stock look
the single is too loud, the turbo makes enough noise by itself
Old 06-29-2007, 10:38 PM
  #102
LHP
LHP's Avatar
How's the drivability with the throttle system.
It's moving more air,
if you are maxing out the injectors and the fuel pump.
LHP
haywardperformance.com.
Old 07-22-2007, 06:13 PM
  #103
SPECIAL-OPS-S2K's Avatar
im going to do a battery relocate... i have some 4ga wire and an inline fuse for the POSITIVE cable. What im wondering is how you wired yours up? did you just ground the negative to the chassis or did you run a wire back up front for the negative?
thanks for your help!
Old 07-22-2007, 07:16 PM
  #104
fperra's Avatar
Just ground it to a good heavy bolt with a very short run of wire. And use no more than 2 gauge for the ground and positive wire.
Old 07-22-2007, 07:40 PM
  #105
4ga is too small?
Old 07-22-2007, 11:13 PM
  #106
squirrels2k's Avatar
Originally Posted by SPECIAL-OPS-S2K,Jul 22 2007, 07:40 PM
4ga is too small?
yes. 2 guage is best
Old 11-06-2007, 05:24 PM
  #107
webmasterino's Avatar
Wow, yellow really IS the fastest color!
Old 11-06-2007, 05:31 PM
  #108
AirborneS2K's Avatar
Wow GJ on the thread ressurection for the stupid reason of stating more worthless 'my color is fastest' posts.
Old 11-07-2007, 08:21 AM
  #109
copec's Avatar
Can your WI support 100% meth? You could break 600whp that way without upgrading the fuel system...(I'm sure you thought of it)
I still don't think I've seen a maxed GT35r powerband on a F20c...the power doesn't crest over significantly before redline.
Old 11-07-2007, 08:28 AM
  #110
fperra's Avatar
Yes it can, but I'm not interested in any more power. If I was I would add another fuel pump. 585 whp is too much for the street anyways. I have the boost turned down to 14 psi which is a little less than 500 whp, and that is a hand full.
Quick Reply: ITB Turbo Part 2
