14mm bolt hold just forward to header
Old Mar 29, 2008 | 01:46 PM
jwa4378's Avatar
Default 14mm bolt hold just forward to header
Hey everyone-
I am finishing up the odds and ends while waiting on the finishing adapters for the oil feed line for the turbo. I was putting everything else back together and I noticed a 14mm bolt hole that is just forward of where the header mounts on the passenger side of the engine. I am wondering what goes in this hole? It does not remain open, right?
I think it may have something to do with the secondary air system that I removed a week ago when prepping for install, but am not sure.
Should I just plug the hole with a bolt? Or is there something specific that goes there? Definitely a 14mm bolt too... much larger than any other bolts around it, so it seems logical that it serves a purpose.
Thanks again.. sorry for my noob-ness.
John
Old Mar 29, 2008 | 01:57 PM
NFRs2000NYC's Avatar
Vtec solenoid?
Old Mar 29, 2008 | 02:08 PM
jwa4378's Avatar
^ I thought the VTEC Solenoid was right above the oil pressure sensor... but I could be wrong. This is just rear of that, above the forward most of the header studs (the last stud toward the front).
John
Old Mar 29, 2008 | 02:27 PM
PeanutButter's Avatar
Remains open,
This is generally where people mount thier engine dampers to.
Old Mar 29, 2008 | 02:36 PM
jwa4378's Avatar
Awesome. I thought I saw a few pics of header installs in the gallery that had it left open. What was the purpose of this from the factory, if anyone knows... There is nothing from the OEM header that mounts here either...
Thanks
John
Old Mar 29, 2008 | 06:22 PM
PatS4P's Avatar
Banned
I think it's an attach point where you would mount a bracket when removing the engine, pretty sure the manual shows it as an attach point. That's what I used it for.
Old Mar 29, 2008 | 06:26 PM
correct
Old Mar 29, 2008 | 09:09 PM
05TurboS2k's Avatar
I just looked at that yesterday, thought perhaps I had forgotten if the heat shield went to it or something.... hmm I think i'll be doing a bit of motor mount support there myself as well.
Old Mar 30, 2008 | 07:56 AM
jwa4378's Avatar
Sweet. Learn something new everyday!
Thread done.
John
svencarlson07
Oct 28, 2010 11:51 AM
ttang
Nov 23, 2009 02:25 PM
gregsju29
Sep 25, 2008 12:58 PM
TelosHedge
May 16, 2008 04:00 PM
Freakaccident
Aug 26, 2002 11:35 PM
