KaNgArOo...going Turbo...
Thanks guys!!! My Down pipe is a tight fit as well, but thats why i went with Innovative 75a mounts to make sure the motor doesn't rock.
Test fitting everything trail #1!!!
Yes, the dump tube will be coming out the hood.
!!! Still need to fabricate the mid-pipe and the hot side charge pipe. Slowly but surly, this build is getting closer to being done. (If you're wondering about that kink in my crossbeam, it's because i had to to fit my oil drain line from when i was supercharged.)
Getting closer to finishing this project. Can't wait to get it on the dyno and drive it finally. Andy and i decided that a 3 ply 90*coupler would be easier than trying to weld on a 90* aluminum elbow.
Andy (friend doing the build) started working on the fuel setup.
Got the battery in the trunk. Andy will be building a cover so we won't even be able to see the battery.
Still need to fab up the 1 foot or less hot side charge pipe as well as the mid pipe for the exhaust. Other than that, it is very close to being complete.
