Kraftwerk sc w/ Gram fuel pump issue
Old Jan 18, 2016 | 11:24 AM
FoBi3s's Avatar
Default Kraftwerk sc w/ Gram fuel pump issue
Hello guys, I need a bit help here. I just installed the Kraftwerk SC about 3 months ago and now the Gram fuel pump only work when it feel like it. So after reading the forums people suggest to replaced it since Gram is notorious for failing.
After replaced it wit AEM 320lph pump it worked a few times now the same issue happen again. It will turn on whenever it feel like it. What else am i missing here? Thanks
Old Jan 18, 2016 | 11:39 AM
chefs2000's Avatar
Sos wiring kit
Old Jan 18, 2016 | 01:25 PM
FoBi3s's Avatar
I just unhooked the battery for 5 hours and it worked again.. sigh so you think it the power shortage problem with factory wire?
Old Jan 18, 2016 | 04:33 PM
JUSTINTHECOASTIE's Avatar
OR your battery, how old is it? Also do you hear it priming before you crank? If it does prime, does it not crank and start?
Old Jan 18, 2016 | 04:45 PM
FoBi3s's Avatar
the battery is brand new. it doesnt prime when turning the key on that's why it doesnt start. once it start it go just fine.
technically it prime whenever it feel like it.
Old Jan 21, 2016 | 04:01 AM
CRVRX's Avatar
As much as we love the Kraftwerks kit. We don't use the Grams pump
I had 2 grams pumps fail and that's all it took.
Every kit we install gets a Walbro pump. We have sold 1000s over the years never had a bad one.
https://www.youtube.com/watch?v=5SGvrV0Vh6o
Old Jan 21, 2016 | 09:49 AM
jetguy's Avatar
What do you do with all the old grams that come with the kit? Imho , Kraftwerks should just not include a fuel pump at all. I don't think they can offer the walbro , as grams, Kraftwerks, and skunk2 are all the same company. If you couldn't tell, my grams went bad from day one also.
Old Jan 24, 2016 | 04:55 PM
The Machine's Avatar
I also had an issue with my Grams fuel pump. I was hitting boost cuts and it was also getting too hot to where it kept causing the fuse to blow in the kick panel. I upgraded mine to the Full-blown 340lph pump and got the SOS wiring kit. Haven't had a boost cut or blown fuse since.
mikees2k
Dec 6, 2024 06:35 PM
RZA
Sep 20, 2014 11:16 AM
Ek_Jak
May 19, 2010 02:42 PM
s2konroids
Apr 5, 2010 06:32 PM
Venomous S
Aug 18, 2009 06:20 PM
