Kraftwerks Boost Curve question/problem?
Old Jul 13, 2009 | 03:56 AM
lookinco's Avatar
Default Kraftwerks Boost Curve question/problem?
I have the kraftwerks AP1 High Boost youtune kit. Max boost I have seen is around 10psi.
I have noticed that I can only fit full boost (10psi) in first gear. When I am in second, third, and so forth, my boost will only go up to (6~7psi). Is this normal or is there something wrong?
The weird thing is, when in second gear the boost would get stuck at (6~7psi) for a while then bounce to 9~10psi near redline, then when I am in third it would just get stick at 6~7psi.
Any ideas?
Old Jul 13, 2009 | 06:43 AM
camuman's Avatar
maybe booost gauge is broken. try swapping with a friend to verify.
Old Jul 13, 2009 | 01:42 PM
lookinco's Avatar
I just made a video. Will post it up tonight and show you guys. I think it might be a loose belt too
Old Jul 13, 2009 | 02:09 PM
OJRKraftWerks's Avatar
I'm thinking it is a vacuum source and/or boost gauge issue. I believe you are using the belt we recommended on your AP1 high-boost pulley. We have not encountered any slip.
Also, you are getting 10psi in first gear. If you were going to get belt slip, it would be during that rapid acceleration in first gear as well. Also, when belts slip they lose grip and don't get it back the rest of that pull.
-Oscar Jr.
Old Jul 13, 2009 | 02:14 PM
lookinco's Avatar
Thanks for the quick reply !!!! I will double check all the vacuum line.
Old Jul 13, 2009 | 02:16 PM
Mongo84's Avatar
The only time mine saw around 10psi was on the dyno when cooled down. Normally when driving around I see around 7 or 8. You tune kit ap1, I believe the pulley was 7.5 i think that they sent with the kit.
Old Jul 13, 2009 | 03:34 PM
GrandMasterKhan's Avatar
I agree with OJR> its strange your only getting 10psi in first. If the belt were to slip it would more likely to do it in 1st gear.
Old Jul 14, 2009 | 01:09 PM
lookinco's Avatar
Hey guys I have uploaded a video~!
VIDEO
Old Jul 14, 2009 | 01:11 PM
kenny_son's Avatar
[media]http://www.youtube.com/watch?v=Vxg03Hg1RJY [/media]
Old Jul 14, 2009 | 02:16 PM
lookinco's Avatar
Is this normal?
