Kraftwerks Boost Curve question/problem?
Old Jul 15, 2009 | 12:22 PM
  #21
lookinco's Avatar
I just checked the vacuum lines and there are no kinks or leak in the hose. We connected the boost gauge to the BIG vacuum line that connects to the back of the intake manifold.
Personally I do not think it is the gauge's problem as it's response when the engine is in vacuum is very quick and smooth. But I guess I will still double check with them.
Old Jul 15, 2009 | 02:28 PM
  #22
R1_Pilot's Avatar
If you want to make sure your vacuum source is good, then swap it to where your BOV is hooked up to ... the brake master.
J
Old Jul 15, 2009 | 02:47 PM
  #23
lookinco's Avatar
Right now the boost gauge IS hooked up to the brake master.
The vacuum line going to the bottom of the picture is going directly into the boost gauge sensor.
Old Jul 15, 2009 | 02:55 PM
  #24
JustinC's Avatar
typically you always want the boost gauge to be on the straight side of a T, so flip the T, so it is straight to the boost gauge and t's off to the BOV
essentially you would want the boost gauge and the BOV to have a straight shot at the vacuum source
  #25
EternalLx's Avatar
Whats your EMS? cant you datalog to see if the map sensor matches the gauge.
Old Jul 15, 2009 | 03:23 PM
  #26
lookinco's Avatar
Good idea. I am running the Kpro, let me make a datalog later today.
Old Jul 15, 2009 | 05:00 PM
  #27
JustinC's Avatar
lol...I figured you had the reflash, but now I see you have 01, yeah, datalog and we can really see what is going on
Old Jul 16, 2009 | 11:18 AM
  #28
lookinco's Avatar
I switched to another boost gauge and it produced the same result so I do not believe it's the problem with my gauge.
Could it be a faulty diverter valve causing me to lose boost? When my rotrex disintegrated last time lots of metal pieces got inside the intercooler. Maybe some of them go inside the diverter valve and damaged it? Just an idea...
Old Jul 16, 2009 | 04:11 PM
  #29
Boofster's Avatar
I can sell you mine if you want it.
I'm using a proper bov but it makes a lot of noise.
Old Jul 16, 2009 | 04:33 PM
  #30
lookinco's Avatar
I actually have a synapse bov in my garage but never got to installing it. It requires a boost only source and I am not sure where I could find one.
