Kraftwerks Boost Curve question/problem?
Old Jul 14, 2009 | 04:01 PM
GrandMasterKhan's Avatar
That looks about right. You will only hit peak 10psi @ redline which you'll be @ only briefly.
Old Jul 14, 2009 | 04:03 PM
lookinco's Avatar
That's good. I just thought the boost would go up more smoothly.
Old Jul 15, 2009 | 06:27 AM
archtop's Avatar
How did you take that video?It doesn't look like your moving.
That video doesn't resemble my setup at all.My guage is very linear and really smooth.I checked and it climbs all the way to 10psi in 1,2,3,4 no jerkiness at all?
I'm using an Autometer electric vac/boost gauge that uses a stepper motor with peak psi memory and boost warning light.Looks like something is wrong with your boost guage setup.I connected mine to the intake manifold where the PCV valve hooks into. I'm using a vented catch can which deletes the PCV setup so the IM port is used just for the Boost gauge now, works like a charm.
Old Jul 15, 2009 | 06:31 AM
maybe thats why since you deleted the pcv setup?
Old Jul 15, 2009 | 06:58 AM
camuman's Avatar
he isnt moving, thats a memory recall feature with those gauges.
Old Jul 15, 2009 | 07:25 AM
archtop's Avatar
Thanks, didn't know they had that feature,very cool.
Old Jul 15, 2009 | 07:26 AM
JustinC's Avatar
looks like belt slip to me, the needle jumping around like that, not to mention it dropping back, it will sometimes drop at vtec crossover, but thats about it
Old Jul 15, 2009 | 07:28 AM
archtop's Avatar
Could be,it's the ideal place to get an accurate reading and nothings in the way.
Old Jul 15, 2009 | 11:05 AM
lookinco's Avatar
The gauges are Defi BF series electric gauges with stepper motors.
We hooked the boost gauge up to one of the vacuum lines coming out of the intake manifold.
Does the PCV cause the boost reading to be jerky like that? I have an AP2 Valve cover and a krankvent.
Old Jul 15, 2009 | 11:21 AM
archtop's Avatar
I'd call Defi and ask them.Let them know where it's hooked and see what the tech says.Nice looking gauges though.It is possible you have a bad sender unit or a leak/kink in the hose? Does not look right to me.Way to erratic ,mine is as smooth as you'd imagine it should be.
