KW v2 to TTS Conversion Group Buy!
Old Mar 15, 2016 | 09:45 PM
gfresh86's Avatar
Im down for a maybe depending on how much modifications and what the diameters are for the pullies. I want to retain my boost pressure.
Old Mar 16, 2016 | 02:00 AM
06S2k07Si's Avatar
Originally Posted by gfresh86
Does anyone know if the kw crank pulley and blower pulley are the same diamters as the tts ones?
TTS kit pulleys are...
Crank = 135mm for 2.2l... 125 for 2.0l
Blower = 90mm for 2.2l at 8000rpm max or 95mm for 8500rpm max.
Old Mar 16, 2016 | 02:02 AM
06S2k07Si's Avatar
Originally Posted by RAIN H8R
I HIGHLY recommend buying JUST blower, brackets, and mounting system from TTS. I would have a local (to you) fabricator build an intercooler and intercooler piping for your car.
Absolutely 100% BEST OPTION!
Old Mar 16, 2016 | 04:19 AM
The Machine's Avatar
That's the only part I was questioning was the hot side with the KW piping and new bracket with the TTS Kit. The blower sits a little bit further towards the driver side. But it doesn't look like it's that far off. Maybe just a new coupler would be sufficient enough to reach the blower?
Old Mar 16, 2016 | 05:19 AM
06S2k07Si's Avatar
Originally Posted by s2000442
Well I have the race intercooler and all the pipe work including the modified pipe exiting the blower needed to successfully clear the ac lines all coated black. If anyone is interested pm me for a great price.
I am trying something different with my TTS kit.
I have all the piping if anyone is interested. Modified to fit US cars and clear everything. Uncoated raw aluminum. If anyone is interested PM me. Pics are in my build thread.
https://www.s2ki.com/s2000/topic/108...rotrex-c38-92/
I as well am re-working mine.
Old Mar 16, 2016 | 05:20 AM
06S2k07Si's Avatar
Possibly... It might not look very nice though.
Old Mar 16, 2016 | 05:37 AM
06S2k07Si's Avatar
If you use the TTS intercooler or another good quality unit that flows well you should have more boost than with the KW supplied piece. With the supplied TTS intercooler and piping I saw 16.5psi. My friend with his KW kit and all supplied piping and same blower saw 14.5psi. Both on stock 2.2l engines.
Old Mar 16, 2016 | 08:04 AM
gfresh86's Avatar
So then are the kw crank pulley diameters different from ap1 and ap2?
Old Mar 16, 2016 | 08:11 AM
0bsolete's Avatar
Member
Getting an intercooler and piping fabricated from a local shop would cost near or even more, might as well just buy that from TTS as well.
Old Mar 16, 2016 | 09:21 AM
beaudin223's Avatar
dont changer the intercooler , to be honnest le intercooler is big enough on the kw , just make the piping fit the new blower position
