KW v2 to TTS Conversion Group Buy!
Originally Posted by beaudin223
dont changer the intercooler , to be honnest le intercooler is big enough on the kw , just make the piping fit the new blower position
Well technicaly if all the pulleys are the same you should be seeing the same amount of power with no difference if your only changing the brackets.im sure if you replace the intercooler and piping as well itll increase the boost pressure because of efficiency.im seeing 16psi with my kw kit with 100mm blower pulley ap1
Another thing to consider is using brake ducts for a track car. I have the KW kit and Wasp brake ducts in my car. The brake ducts work with the KW intercooler and piping but I doubt they would work with the TTS piping.
The pictures of the TTS kit seem to show that the two pipes on the same side take up too much room to allow another 2.5 inch tube to be installed along with the TTS pipes. The KW kit with one pipe on each side is tight.
I am not sure I will have the patience to continue to post in this thread. Learn from other peoples mistakes. Both TTS equipped cars I have in my area (I managed the install on one, and looked at the other in person), both owners ended up having the charge piping redone.
Do not waste your time with buying the TTS charge piping and intercooler. If you do not have any experience with fabrication of intercooler piping or intercoolers, do not comment or speculate on what you think you could get away with. Financially, you are wasting your time.
Could you use the KW intercooler and piping? Yes.
Would you need to rework the hot side on the blower discharge outlet? Yes
Would a simple silicone hose extension work for this? Most likely not as the angles and distances away from one another do not match up
Would fabrication of the engine bay portion of the hot side charge piping need to be fabricated/welded/modified? YES
Keep in mind, this is all about flow, so having nice radius bends is critical to have optimum efficiency of the kit (more boost pressure = more HP!). The 90 degree bend on the KW kit blower output is hurting air flow and has a direct relation with potential power output.
A comment was made about how 10whp isnt a big deal. That is huge, do not underestimate the difference a single HP can make, do not forget that is actually close to 12 engine hp depending on the drivetrain loss percentage you use. 12 engine hp, that is equivalent to the gain normally seen from a Js header being installed on a car that is already making around 480 engine hp (405-420whp)
