KW vtec solenoid bolts
hi guys ,
i bought a KW supercharger kit last years around october but i did not instal it yes becasue of the winter ( mtl quebec canada )
i read alot on the forum to avoid all probleme that can be appear on the kit , so i alerdy bought few thing to make the kit work fine thr 1 shot , really appreciated all the info here
so now i see few probleme with the bolt crack / brock in he head of the vtec solenoid brackets , i jusy spoke with CJ to have the info abotu the correct spec of the bolt thats seem to be M6 x 1.0 x 60mm , i want to change it for titanium bolt and a higher grade just to be safe !
did you have a good website to bought this kind of bolt ?
thanks
PS : sorry for my anglish its my 2 language
thanks
thats find thanks i just find them here
https://www.pro-bolt.com/titanium-he...-x-60mm-4.html
now in the same time , why not just change them all ?
i mean on the revised kit V2 the bolt number 5 , that one are suposed to be the num 10 on the original kit
i mean the 2 bolt that hang the revised bracket to the front plate , i seen some where they broke too right ?
they are number 10 on the instlation instruction spec size M10x 1.25 x 40 , should i change them too ?
10.9 or even better a 12.9 should be plently. It's what I did with my solenoid bolts on my Vortech
Originally Posted by beaudin223' timestamp='1454642396' post='23871928
well its 122.78$ + taxe + us to Can conversion so around 200$ for 6x bolt jesus its way to much expensive , did i really need those bolt ?
Originally Posted by iDomN8U' timestamp='1454681356' post='23872204
[quote name='beaudin223' timestamp='1454642396' post='23871928']
[/quote]
10.9 or 12.9 should be plently, if you're breaking those bolts, there's a bigger problem.
