Laminova oil cooler
Old Aug 28, 2012 | 11:38 AM
nissfam's Avatar
Default Laminova oil cooler
Anyone running these with there turbo setups? I am looking at oil cooling options for my setup....
Old Aug 28, 2012 | 06:34 PM
nissfam's Avatar
Hmmmm... Nobody? I know the guys with craftwerks run them. What are some of your oil temps like with it? What other oil cooler setups are you turbo guys running?
I am running an inlinepro 6265 setup. It will be a street car. I deleted my OEM cooler/heater, should I still run a cooler of some sort?
Old Aug 28, 2012 | 06:48 PM
miguel329's Avatar
Setrab oil coolers 13 row should be plenty, make sure you get oil thermostat so oil doesnt go into oilcooler before operating temps.
Old Aug 28, 2012 | 07:23 PM
iDomN8U's Avatar
Laminova oil cooler are a good idea, I was thikering with the idea.
http://www.batinc.net/laminova.htm
I would recommend the largest one (better to over cool then under) but have no personal experience.
Old Aug 28, 2012 | 09:06 PM
hybridsol's Avatar
After reading their info, looks like you'd:
  • put this in the main return (top) to the rad
  • remove and plug the stock cooler
  • mount an adapter housing to the stock filter location
  • add a thermostat (oil side)
  • install a remote filter
Old Aug 29, 2012 | 04:50 AM
myflys2k's Avatar
I was going to go the laminova route but ended up getting a 19row setrab oil cooler w thermostat. If your car is a street car with no track time then I hear the laminova is fine. Get the largest one you can fit.
My 19row setrab oil cooler works ok but I need to add a shroud around it to force the air through the oil rad. This should make it more efficient ans suit my needs. My oil temps after 15 laps at local track day was around 250F. Ambient temp was around 85F. I removed the oem cooler. I'm only at 319whp vortech supercharger.
Old Sep 3, 2012 | 06:09 PM
miguel329's Avatar
I google s2000 laminova oil cooler found few people using them, but setrab air cooler do good. Here is one link of a guy you could pm him
https://www.s2ki.com/s2000/topic/785...eat-exchanger/
Sent from my PC36100 using Tapatalk 2
Old Sep 3, 2012 | 06:54 PM
Spec_Ops2087's Avatar
I have one and it works great. Search my name as I have an install / impressions thread from a few years back.
Old Sep 4, 2012 | 10:43 AM
iDomN8U's Avatar
https://www.s2ki.com/s2000/topic/792...#entry18838760
biohazarde
Feb 24, 2014 04:58 PM
neoleooo
Aug 20, 2012 08:10 AM
GoOn3
Jun 21, 2011 05:07 PM
skool u
May 25, 2009 09:39 PM
rick bailey
Nov 2, 2005 12:29 PM
