Lets talk about radiators/cooling
Old May 30, 2012 | 04:43 AM
  #31
o'malley_808's Avatar
Originally Posted by teamvalorracing
Did you pull the ic and do any testing? There is a lot of info to be had from that test alone and will point ou in a direction instead of speculating.
Yeah that is my next test. The oem rad test resolved one of my issues. I was playing around with the undertray ducts also.
Old May 30, 2012 | 04:46 AM
  #32
teamvalorracing's Avatar
those are important too. do you still have yours?
also, if you are aem, why do you have the oem fan switch controlling your fans?
Old May 30, 2012 | 04:54 AM
  #33
The undertray was installed before and I tried removing it but saw no change in temperature.
I followed a few of the settings posted on s2ki to control the fans and all I get is a bunch of relays clicking in the main fuse box.
Old May 30, 2012 | 05:04 AM
  #34
here is my screenshot:
Old May 30, 2012 | 05:10 AM
  #35
and another with the important coolant ratios and air temp ratios in view for you to compare with:
Old May 30, 2012 | 05:33 AM
  #36
I'm running the series one so im using AEMpro instead of AEMtuner. Similar deal though. I tried controlling LS8 in the configure outputs and just get a bunch of clicking.
Old May 30, 2012 | 06:33 AM
  #37
Odd. Are your coolant volt/temp values the same? I am using reg s2k settings, .ot the revused ones. Driving 24 miles to work through mostly city roads in a muggy 81 degree florida morning, i saw 185-192 with those cals.
Gorg
Sep 14, 2014 09:31 PM
lilsharky
Sep 27, 2011 04:28 AM
Spies
Oct 17, 2009 04:29 AM
mpower22
Jul 25, 2007 11:03 AM
