lets talk redlines
Old Mar 26, 2014 | 05:52 AM
passmans2kny's Avatar
Default lets talk redlines
whats up guys, so I will be getting my car back on the road soon with a few changes to my set up(turbo, intercooler and piping, dumps, blah blah) but one thing I wanted to bring up was my redline, I switched to an ap1 intake cam this time around, have a fully built ap2 bottom end 11:1 comp, full ferrera valve train, I was thinking about running 9000, thoughts? insight?
-matt
Old Mar 26, 2014 | 06:22 AM
baZurk's Avatar
What is the stroke of the new motor?
Old Mar 26, 2014 | 06:59 AM
stock ap2 stroke i guess, its actually an ap1 head on my block this time, but with my ap2 exhaust cam and an ap1 intake cam
Old Mar 26, 2014 | 07:00 AM
baZurk's Avatar
If it is still an ap2 crank then I would keep redline at 8500. I don't know if your aftermarket pistons/connecting rods take away any rotating mass or even if that increases that safe limit for revs.
EDIT: Who built the motor? What do they say?
Old Mar 26, 2014 | 07:57 AM
its cp pistons, crower rods, i went with super thick wrist pins this time so thats def added weight there, and the rods are def heavier than stock, im guessing the pistons are similar in weight to stock, so over all its heavier than stock, john at machine world built the motor, now hes become wre, wright racing engines
Old Mar 26, 2014 | 11:20 AM
bruthaboost's Avatar
Your piston speed will be high (mean speed of 27.21 m/s) as well as your side loads as a result of the shorter rod and greater momentum from your higher piston speeds. That's F1 territory for piston speeds.
Old Mar 26, 2014 | 11:34 AM
Honda_Mad's Avatar
If it makes power past 8500 and built right I don't think u will have issues revving it to 9000 rpm
Old Mar 26, 2014 | 11:40 AM
funkyWEASEL's Avatar
if you have the funds to rebuild it if 9000 hurts the motor, go for it. If you do not want to risk losing the motor, 8500 is sufficient.
Old Mar 26, 2014 | 12:32 PM
Redline S2K's Avatar
You rang?
I wouldn't go past 8500 with an ap2 crank.
Old Mar 26, 2014 | 02:26 PM
1SlowSi's Avatar
You will have no issues revving to 9K since your motor is now built from head to toe. I have been revving to 9k for 3 years without any issues. Others on AP2's have been revving to 9500k without issues. I would just stop where it stops making power.
