Liquidgsr Laguna build thread
Old Feb 27, 2013 | 02:53 PM
  #281
Reapur's Avatar
Originally Posted by camuman
Originally Posted by Reapur' timestamp='1362004428' post='22368866
[quote name='liquidgsr' timestamp='1362001350' post='22368739']
I haven't decided yet. The R888s are R comp correct? Most likely the R comp.
Streeting R comps is expensive and foolish. Heat cycling them on the street will ruin them quickly and req them to be replaced frequently. Star Specs have been more than adequate for me at 450whp. Real Street Performance runs star specs on their drag car in street trim.
Basically if you're street driving use a street tire.
Sent from my iPhone using Tapatalk 2
Disagree. I've got 20k miles on my ra1's and they still work great. I think people overreact with this whole heat cycling thing.
What's the point of serious power if you have to limit it till fourth gear. Smh
[/quote]
I'm not boosting by gear. Straight off the boost controller. No issues with traction 255 star specs 450whp 300wtq.
First gear steps out 2nd gear chirps slightly 3rd gear is full traction. The street tire will last longer and be far safer on the street especially if you get caught in rain, which may happen.
Old Feb 27, 2013 | 03:12 PM
  #282
camuman's Avatar
Originally Posted by camuman' timestamp='1362004744' post='22368880
[quote name='Reapur' timestamp='1362004428' post='22368866']
[/quote]
[/quote]
Mine spun hard on street tires. Ehh I'll give e you the rain problem though. At half thread my ra1 look like slicks Heheheheheehe.
Old Feb 27, 2013 | 03:37 PM
  #283
d-bo's Avatar
Great looking car and build! Mine is taking a lot longer than i originally thought too. Seems both of our problems stem from using BW turbos lol
that ptuning vacuum block is ill. that's the first time i have seen that. might have to pick one up now
good luck
Old Feb 27, 2013 | 06:56 PM
  #284
Reapur's Avatar
Originally Posted by Reapur' timestamp='1362009188' post='22369041
[quote name='camuman' timestamp='1362004744' post='22368880']
[/quote]
[/quote]
[/quote]
Which street tires?
Old Feb 27, 2013 | 08:28 PM
  #285
miguel329's Avatar
I loved my star specs good tires. No traction issues. .. good and very rain friendly
Sent from my SPH-L710 using Tapatalk 2
Old Feb 28, 2013 | 04:38 AM
  #286
liquidgsr's Avatar
Yeah I will see when I get my car back what tires I want to get. At this point I just want it back and want to drive it. Its been so long I don't even mind just driving it off of the Wastegate and probably be happy for a bit.
Old Feb 28, 2013 | 04:49 AM
  #287
camuman's Avatar
welp, toyo has axed the RA1. that blows major goat balls. i am looking at the hankook rs3. the r888 is prolly awesome in dry weather, but rain you would die. ra1 at least was super rain friendly until half thread. also looking at nitto tires. super sad face. my rears are at half thread, so i could prolly get away with replacing those in a year, but the fronts are at 65-70% and they dont make those anymore. i am picky about this car, i want fronts and rears to match. oh well, running these to the ground then worry later.
look at the rs3 though. very sticky street tires at a bargain.
Old Feb 28, 2013 | 05:10 AM
  #288
camuman's Avatar
pilot sport cup tires. mmmmhmmmm.
Old Feb 28, 2013 | 05:41 AM
  #289
herecomesboost's Avatar
No love for ET Streets? My last set held up quite well (they were still on the car when I sold it).
Old Feb 28, 2013 | 05:48 AM
  #290
liquidgsr's Avatar
Are the ET streets drag radials? The Ventus RS3 might be the right tires. Again I pretty much put this setup to see what she could do, but by no means as I am going to run it at full power all the time. Its more of a fun street car with the ability to push it to higher numbers when I want to. Like you guys said, just running through the gears wont be fun at all.
