No update today either shop was closed. I'm almost sure it's a ground issue. It doesn't add up for the starter to be bad. Hoping they will figure it out.
Ask the shop to use a power probe ( im sure someone in the shop has one) and jump the signal wire on the starter...it should start/crank if not then ur gonna need a starter
It is probably not goin to start up perfect the first time while being tuned so roll starting is likely to not work.
Very true easyest way to find out is pull starter and check it out side of car to me sounds hung up mine did it and had to have it rebuilt took the guy a hour and cost like 55.00 now works great
worst comes to worst i can pull mine and you can use it to tune and then shoot it back to me. be a week or 2 before i get mine running again. let me know!
