Liquidgsr Laguna build thread
Old Mar 11, 2013 | 12:06 PM
  #361
camuman's Avatar
Originally Posted by S2K-F8
Originally Posted by camuman' timestamp='1363030306' post='22396326
i woudlnt be surprised if your yellow top is done. mine did the same thing.
Same here, 2 yellow tops in 27 months
in my yellow tops defense it lasted 6 years rofl. but i ran the group 34/78 one.
Old Mar 11, 2013 | 12:31 PM
  #362
liquidgsr's Avatar
I used to swap my original s2000 battery and my yellow top between my corolla and s2000 when I needed to put the top up or test something and it always worked perfect in my corolla. Never had a starting issue. Something is draining the battery when its plugged in though and I have to figure out what it is because in 2 days if the car isn't started the battery gets drained.
Old Mar 11, 2013 | 12:37 PM
  #363
camuman's Avatar
i am 99.9999% sure your battery is toast. mine did the exact same thing. i put in a walmart crappy battery and it fired right up. left the car alone for three weeks, fired right up.
seriously, try a new battery. its worth the attempt. or have the shop physically take that battery out and out one in that works from another car.
Old Mar 11, 2013 | 12:41 PM
  #364
herecomesboost's Avatar
Nesar, I have a (nearly) brand new battery if you'd like to pick it up (I'm using a PC680, so I don't need the stock unit). Free if you want it.
Old Mar 11, 2013 | 12:54 PM
  #365
liquidgsr's Avatar
Oh thanks Kyle. Yeah I will pick it up.
Old Mar 11, 2013 | 01:18 PM
  #366
Cool
Old Mar 11, 2013 | 01:24 PM
  #367
spectacle's Avatar
Optima batteries are garbage and I would not recommend anyone use them under any circumstances.
Old Mar 11, 2013 | 06:45 PM
  #368
d-bo's Avatar
i had a mini golf cart battery (thing weighed like 2 lbs lol. started every time tho!) but my friggen car sat outside for a month in 10 degree weather while my exhaust was "getting made" and its fcking garbage now. i put my oem honda battery that i hadn't touched in 8 months in and it started right up. same symptoms. my battery also read as charged on my trickle charger. it wouldn't jump start either
Old Mar 12, 2013 | 04:54 AM
  #369
liquidgsr's Avatar
I did email and left them a message asking them if they could swap the battery to see if its the culprit, but I would think that might be one of the first things they try right?
Old Mar 12, 2013 | 05:29 AM
  #370
sata3000's Avatar
you would think but never know.. id say its worth a shot
