Log manifold cracked twice !
I noticed you had issues with misfires and the car running poorly. Please send me your ignition map as well. Might sound weird but if you are blowing chunks off the manifold, the egt must be through the roof due to extremely retarded ignition timing.
Either way we will take care of you. We have to find out what is causing it.
Sent from my Galaxy S II using Tapatalk
I contacted the tunner and he said that he already welded the manifold, and the surface of the manifold wasn't perfectly straight so it leaks exhaust gas when it was fixed to the engine .. he resurfaced it and installed it with a new gasket, he told me also that he made brackets to hold the downpipe so it won't shake
additional info : the dump tube is welded to the downpipe .. and my BOV is not connected to anything so I think I'm running waste gate only
CounterSunk
Nov 5, 2014 12:24 PM
