Loss of fuel pressure...
Old Jun 5, 2011 | 05:14 PM
ghettocrxsi's Avatar
Default Loss of fuel pressure...
Ok I am buttoning up all the loose ends on my car and I am having a stupid problem.
When I cycle the key on I get 60psi fuel pressure and after the pumps shuts off after 10 seconds or so it drops to 43psi. Then I go to start the car and it comes on for about 3 seconds and dies.
I figured it was because of the inline pro return line and walbro 255 being installed and only having a little gas in the tank. So I put 5 gallons into it and still the same thing.
The walbro has been rewired to the battery with 8 gauge and a relay. Maybe I have the wiring wrong? I dunno with all the s2000's I have going right now this one is starting to piss me off.
Could be the kpro map?
Any ideas guys I am all ears.
Setup:
07 s2000
inline pro return fuel system with walbro 255.
Doolots performance twin scroll custom turbo kit
Injector Dynamics 1000cc injectors
kpro dual ecu.
Old Jun 5, 2011 | 06:00 PM
*JG*'s Avatar
Sounds like its going to be something in the wiring. Maybe you have the connectors in the wrong place on your relay? There is a good write up on hard wiring the pumps from google.
Old Jun 5, 2011 | 08:48 PM
20002point2l's Avatar
i had this problem, turns out the relay went bad. swapped it out and it works fine now.
Old Jun 5, 2011 | 09:53 PM
Going to work on it a bit tomorrow, It's weird that it will prime up and then dies out..
Chance S2K
May 14, 2015 07:16 AM
s2kjn
Sep 29, 2014 12:25 AM
Weasel497
Jun 13, 2014 05:57 PM
herecomesboost
Aug 8, 2012 02:53 PM
S2K-F8
Sep 22, 2011 06:57 AM
