LoveFab turbo coolant lines
Old Aug 15, 2005 | 05:41 PM
AusS2000's Avatar
Default LoveFab turbo coolant lines
I installed the coolant lines by removong the short hose from the coolant bleed valve to the throttle body and attaching the two hoses to these points.
Black hoses from turbo.
The hoses are a loose fit on the fitting but I got a seal by tightening the clamps down hard. Not ideal, but it is holding nicely.
Today I was reading about flushing coolant and noticed the line to the oil cooler. I wonder if this is a better point? It would certainly look cleaner. I wonder if it would fit better.
Old Aug 15, 2005 | 05:52 PM
kane.s2k's Avatar
I was going to route my water lines from there originally but then I realized it probably wont flow enough through the turbo so I took mine from the smaller diameter TB lines.
Old Aug 15, 2005 | 06:05 PM
JDMKID35's Avatar
Banned
what the hell is that pipe that looks like a monkey bar?
Old Aug 15, 2005 | 06:10 PM
AusS2000's Avatar
That is a monkey bar
I trust you mean the unpolished pipe from the BOV to the intake tube. It's simply the bypass pipe. The idea is to keep the BOV noise down. ALso, being a closed system it is closer to legal. I will eventually have all the engineering checks done so it is fully certified.
Old Aug 15, 2005 | 06:53 PM
Scorpion's Avatar
So that won't work? That sucks cause that's what I was planning since I have to replace that piece of 1/2" hose anyway...slipped with a razor knife
bobonacus
Oct 12, 2016 12:47 AM
SPECIAL-OPS-S2K
Jun 6, 2008 10:50 PM
MuckaLun
Jan 8, 2008 03:53 AM
PeanutButter
May 18, 2007 06:46 PM
2NRWRNCH
May 15, 2006 10:36 AM
