Low compression Franken S2k motors?
Ok its offical im going to build one! The only thing I still need is pistons, rings and rod bearings. Will post pics up as the build progresses. And of course I will be using the stock hg
while you are at it might want to see if you can get some aftermarket rod bolts. I know they were issues on other honda engines. If you plan on making a lot of power it cant hurt since you are doing a rebuild anyway. Keep us updated. Maybe i will do one of these this winter.
How about doing the AP1 crank with AP2 rods and pistons and then milling the block to achieve something like 8.8-9.5 CR? I guess one would have to mill an insane amount to make it work.. thoughts?
Edit: Any effects on timing chain if the block/head was to be milled by a rather large amount?
