Posted this i general but got few hits. Maybe someone here cant point me in the right direction.
Car started loosing oil pressure friday. 11psi idle 45psi at 3k rpm. So I took the oil pan off and found copper from a plain bearing along with what looks like part of a cage of a ball bearing, also made out of copper. I have no idea where this came from.
rod bearings were fine. The center main bearing is toast and it damaged the crank journal on one half.
Thrust washer shows some wear, but not horrible. Running a CM-FX500 clutch
Are these cranks nitride coated? Can they be reground?
The middle main bearing eh' ... care to say what oil you were running?
I have a feeling that piece you found that looks to be from turbo could have been a culprit, but to me a middle main failure imo points to harmonics or loss off efficiency on the harmonic balancer, etc etc. just wondering. Was it a crazy setup? How did it feel b4 failing?
oh and i would not bother with a re grind, let her RIP.
Find a good one or go Fresh K crank. Probably just as affordable.
running rotella t6. Was making mid 5s on power. Motor had 110k on it. Crank is at the machine shop now, he said it wasnt bad at all.
