Manny-s2000 build thread
The filter I am unsure of the specs but I have the model number here: RU-2510
It's a k&n filter. It also involves shaving the bonnet pin holder though, that's why I went with gas hood struts.
Nice build man. From looking at the pictures, I believe you may have the catch can setup plumbed wrong.
You have a hose running from the intake manifold to the catch can and then one from the pcv valve on valve cover to the catch can. The catch can is also vented it looks like. Won't this cause a vacuum leak since the catch can is vented? It also doesn't seem like the best option to relieve crank case pressure. My advice would be to run both valve cover ports to the vented catch can and cap off the intake manifold port. Also gut out the pcv valve when doing so.
Someone else chime in.
Thanks,
Manny.
Finally!
Looks good man. I just left my PCV/breather open for the time being. I plan on removing the PCV and running a catch can that connects one port to the breather and the other to the stock PCV location (using an AN adapter). Can't wait to hear it. Good luck on the dyno!
Finally!
Instead of using an AN adapter is it possible I just gut out the pcv as Mportracer33 mentioned? Is the pcv valve even needed?
Is your stock PCV threaded into the valve cover? On AP2's the PCV is threaded, so it's as easy as removing the old PCV and installing an AN adapter; not sure with an AP1. You can gut the PCV. It's not needed with your setup.
Originally Posted by manny-s2000' timestamp='1343827229' post='21904599
Thanks Kyle
