MAP request.
Old Apr 18, 2007 | 05:07 PM
ChefJ's Avatar
BTW how far did you drive it??
Old Apr 18, 2007 | 05:15 PM
Planets's Avatar
I drove it a long way, and I dont recommend doing this (in other words, if you drive it and something goes wrong with your engine, dont come running back here to blame me ) but I drove it all the way from central oregon up to portland. Few hundred miles. Ran beautifully the entire way, like I said not even a single CEL. This was on a built engine on stock injectors, with the stock ECU.
Old Apr 18, 2007 | 05:26 PM
ChefJ's Avatar
hmmm
I will be on a 3mm headgasket and stock injectors, stock ecu. hmm...
Old Apr 18, 2007 | 06:01 PM
revhi's Avatar
Im thinking it would be fine to, I mean what kind of tuning would the base map need to have? Your not adding more fuel or air that needs to be accounted for yet.
Old Apr 18, 2007 | 06:15 PM
ChefJ's Avatar
I was just worried about timing actually. I heard that it may need to be retarded somewhat.
Old Apr 18, 2007 | 06:41 PM
revhi's Avatar
Isnt the emenage's timing control very limited from what kane said? I run an emanage, but never messed with timinig.
Old Apr 18, 2007 | 06:43 PM
ChefJ's Avatar
It may be quite limited. I won't know personally until I talk to the guys tuning my car. Although I have purchased everything that you possibly can for the emanage blue.
Old Apr 27, 2007 | 03:41 PM
A4XRBJ1's Avatar
It is. That's why I run the timing actually through Vortech's timing control box, I use the Greddy only for the fuel.
Andreas
Old May 1, 2007 | 12:28 PM
ChefJ's Avatar
Not to bring this back but some of you had wondered about a stock ecu and injectors running on a lower compression and I am telling you it runs almost the same. Up to 6000 rpms anyway.
jooseung
May 16, 2016 11:03 PM
scutrCR
Feb 28, 2010 07:43 PM
dmw16
Jul 1, 2006 12:10 PM
GDM S2K
Apr 17, 2006 09:41 PM
shogun
13
Sep 4, 2003 06:09 PM
