Mase Engineering S2000 Turbo Kit
Old Jun 3, 2010 | 08:10 PM
  #91
camoy's Avatar
Originally Posted by wait4vtec,Jun 3 2010, 05:34 PM
where could i get that?
It should have came with the kit
Old Jun 3, 2010 | 08:22 PM
  #92
GrandMasterKhan's Avatar
Originally Posted by dsddcd,May 31 2010, 11:08 AM
No, you have to gravity drain back to the pan.
Why couldnt it be done this way? Wouldnt that technically be a pressurized system which would feed the oil through the turbo and draw it back to the engine (through an external cooler and oil filter?)
Old Jun 4, 2010 | 06:49 AM
  #93
MaseEng Nick's Avatar
he bought his kit used... so he didn't get this piece.
Old Jun 4, 2010 | 09:22 AM
  #94
dsddcd's Avatar
The drain is not pressurized, well that is as long as you are venting the crank case pressure correctly.
Think of it like this, we know fluid moves from High pressure to Low pressure, so if you have a garden hose that you close the nozzle on there is no flow inside the line b/c it is all at the same pressure. However when you open the nozzle at the end you start flowing. The only way this would change is if the turbo was an oil pump also but that is not the case. So you pressurize the inlet and do all that you can to lower the pressure on the outlet. Some applications also require a scavenging pump b/c they cannot take advantage of gravity or have exessive crank case pressures.
Old Jun 4, 2010 | 06:59 PM
  #95
camoy's Avatar
Wow someone sold a used kit already?
Old Jun 29, 2010 | 07:27 PM
  #96
daicacharco's Avatar
Anyone with a 06+ have this kit yet?
Old Jun 30, 2010 | 07:45 AM
  #97
MasterForce's Avatar
i dont know if i should get a smaller pulley for my s/c or just sell it and get this one.
Old Jun 30, 2010 | 04:58 PM
  #98
TurboCongo's Avatar
Just go turbo! And Mase is the man to do it with... No homo!
Old Nov 19, 2010 | 04:10 AM
  #99
Rob@ReidyRacing's Avatar
Roll on December the 18th!
Old Nov 19, 2010 | 06:09 AM
  #100
vadik_s2k's Avatar
Just curious if my dbw returnless fuel system has any restrictions compared to 00-05 models? Possible to run 18+ psi with ID1000's and walbro 255?
