Mase Engineering S2000 Turbo Kit
Originally Posted by chilenny,Apr 26 2010, 11:16 AM
Instead of tapping the oil pan. Is it possible to use the oil drain plug adapter that CTSC uses? Then you can bring the car completely back to stock instead of buying a new oil pan.
Originally Posted by GrandMasterKhan,May 31 2010, 03:44 AM
I am curious. Instead of tapping the oil pan, could you use a sandwhich plate @ the OEM oil filter location and run the oil lines to the turbo from there then through a larger external oil cooler?
heres my situation, the shop that put my kit on capped this cooler line because he said it was to close to the manifold but i want to get a longer hose and reconnect it with a heat sock/sheild
thanks for the help
thanks for the help
