MASSIVELY HIGH INTAKE TEMPERATURES
Old Oct 13, 2010 | 11:51 PM
IMSMEISTER's Avatar
Originally Posted by MugenRioS2k,Oct 13 2010, 06:44 PM
Any decent code scanner will tell you your IATs.
but may miss spikes since the refresh rate is not that good on most scanners.
I have a buddy at a local Honda dealership. Will take it there to check the IAT.
Will it also help to check the MAP sensor and throttle sensor?
Old Oct 13, 2010 | 11:52 PM
IMSMEISTER's Avatar
Originally Posted by Kyushin,Oct 13 2010, 07:17 PM
Im with sideways on this one, just pull the cap on your charge cooler and make sure there is water flowing and if not then you will need to do some repluming.
I checked the cooler already. The pump comes on and the glycol mix is swirling when you take the cap off.
Old Oct 13, 2010 | 11:54 PM
IMSMEISTER's Avatar
Originally Posted by DesertWanderer,Oct 13 2010, 07:14 PM
I would also recommend that you replace the Royal Purple with something more appropriate.
Royal Purple is apparently a good oil to use.
Do you suggest otherwise?
Is it possible that the charger doesnt like this oil?
Old Oct 13, 2010 | 11:58 PM
IMSMEISTER's Avatar
Originally Posted by Slows2k,Oct 14 2010, 01:50 AM
Stock NA cars can hit 190F no problem on a hot day. You need to actually check the IAT
Wow - thats high. Our readings are in Celsius and was advised that temps above 60 degrees are high. That equates to about 131 Farenheit
Old Oct 14, 2010 | 11:29 AM
Moddiction's Avatar
Former Sponsor
My v2 vortech blower has a grinding noise that kind of pulsates. Seems to be normal.
Old Oct 14, 2010 | 11:34 AM
camuman's Avatar
131F read at the stock iat location in the intake mani is completely normal.
hell even with your aftercooler you can still easily hit 150-180 iats.
i had to spray water/meth to get mine to wihtin 10-15 of ambient.
Old Oct 14, 2010 | 11:40 PM
IMSMEISTER's Avatar
Yip - that would probably describe it best.
99SH
Sep 27, 2012 08:50 AM
urBan_dK
Oct 9, 2010 02:42 PM
SRap1
Oct 9, 2010 10:42 AM
yiannakos
Apr 18, 2008 11:00 PM
snakeeyez
Aug 12, 2005 05:30 PM
