Max boost on stock block
Old Apr 26, 2018 | 12:11 PM
  #21
nguyen365's Avatar
Originally Posted by AP1Chief
31lbs bw362
studs and valvetrain
How much did those studs and valve trains cost u? Did u use supertech? I think if I did that I can probably max my gtx3076 at 27psi? What do u think?
Old Apr 26, 2018 | 01:09 PM
  #22
riceball777's Avatar
you should max out at way lower psi that that. My gen1 gtx3076r maxed out at 588whp at 21psi on the stock block.
Old Apr 26, 2018 | 04:14 PM
  #23
nguyen365's Avatar
Urs is stock unopened block right? Which injectors do u run?
Old Apr 26, 2018 | 04:27 PM
  #24
Mijae007's Avatar
How do you know what psi a turbo maxes out at? Does it stop making power at a certain psi? Cause i know a lot of people make a hell of a lot more power than what the manufacturer rates their turbos at.
Old Apr 27, 2018 | 04:51 AM
  #25
AP1Chief's Avatar
alot has to do with how much a turbo makes at what psi..
Your flow mods, Fuel, and your DA to where you live.
I wouldn't over spin a turbo out of its range from the manufacturers compressor map graph. I know what it does LOL
Old Apr 27, 2018 | 04:52 AM
  #26
AP1Chief's Avatar
TO the OP Its not about psi its about torque.
AT 450-500 your pushing the stock rods, at 550-6 your pushing the stock pins.
IF your over 500tq, i would start saving up for a bottom end.
Nine1Sickness
Mar 28, 2009 08:35 AM
HvRRZ
Feb 12, 2009 07:47 AM
abv
Jun 1, 2007 01:43 PM
nsxinsac
Nov 8, 2005 12:38 AM
adam_gipson
Jul 5, 2005 12:35 PM
