Map sensor help
Old 12-28-2017, 10:06 AM
hondacrazyhonda's Avatar
Default Map sensor help
yes i searched bahahahaha.
I have an AP2 doing a turbo build. I will be running an aem ems series 2 I purchased a science ofspeed 4 bar map sensor. When i recieved it the sheet it comes with says its not compatible with the series 2. Talked to sos and the said i need to run dual map sensors. One wired into the aem ems for boost and that i need to retain my stock map sensor but i need to find a map blocker so the stock map doesnt read boost. Kinda confused. never ran into this problem. Any help or input would be appreciated. Anyone else running a series 2? ill be boosting at around 15 pounds. I was thinking about just getting a gm 3 bar because i know the ecu is capable or reading that. Just confused about the stock map? Ive always just ran a upgraded map and ditched the stock unit
Old 12-28-2017, 03:09 PM
Series 2 aem guys 2007 on up are you running a missing link?
Old 12-28-2017, 03:23 PM
AP1Chief's Avatar
You can hit me up on the topic if you want.
I do a lot of S2ki member tunes on v1/v2
i always suggest Omni 4 bar, and you’ll never need to buy another Map sensor again. And it works fine
with v2
if you wanna chat more txt me
7173986782
Old 12-29-2017, 05:55 AM
nguyen365's Avatar
If u're going to over 600hp + u need 4 bar map sensor or over 26psi of boost. U replace our ap2 map sensor. I bought sos 3 bar map sensor and Max psi reading is 26psi of boost. I'm currently on street set up daily driven 19psi at 600ponies. Best advice pick a tuner tell them what u want then they'll help with set-up and tune
Prokaw875
10-01-2012 02:29 PM
518135
11-18-2008 01:52 PM
gusrock77
09-19-2008 04:26 AM
C45P312
07-04-2006 10:04 AM
waytooslow
04-24-2006 08:04 PM
Quick Reply: Map sensor help
