More info - BAP + Relay
I'm still on this quest to gather as much info before I start the install and my writeup/how-to for you all.
The BAP should be here any day, and the relay I bought came yesterday.
W/that said...I'd like to ask a few more questions.
1. Fuel pump harness. What color is the power wire?
2. In regards to the relay, how should it be wired?
It basically has 5 tabs.
"Assuming" the following:
Ground
Power from batt
Power to pump
OEM pump power
Link to pic of relay here
3. Last but not least, from what I've been told, I need to hook the BAP up to the relay as well, so it gets good clean power directly from the batt. How is this accomplished?
Thanks for any all advice.
Ground
Power from batt
Power to pump
OEM pump power
ok as for wiring use this link here
relay wiring
obviously the colors are different, but it is a very good guide
here are some pics of how I did mine, using 10gauge wire
THIS IS FOR ADDING A RELAY TO THE WALBRO
relay wiring
There are four wires going to the pump. You want to concentrate on the two thicker ones. Get a voltmeter and it will be clear which one is positive. I can check my set-up tonight if you don't have a voltmeter.
As for the relay, I never used one .... not sure why you need one.
J
J
Originally Posted by SgtB,Feb 23 2010, 05:25 PM
Run the same size ground back to the block.
