More info - BAP + Relay
Originally Posted by SgtB,Feb 23 2010, 04:00 PM
The block is ground.
Guess what I work everyday, I don't have the luxury of sitting around waiting for you all to sign a package.
Asked for a re-route to my job, and they said it should be there in the next WEEK, I work 8mins from my house.
omg, I want to kill someone.
FYI, the power wire is yel/grn or grn/yel. One of those two combo's. Can't remember which one but you can't get it confused with any of the other wires. I think the level sensor wire is yel/black or something. The other two are both black.
Nope. I'm not trying to start a argument. The ohms per foot will be lower through a copper conductor. The block is supposed to be the reference point on a proper ground system. Everything else should be off the block in a star topology. (Master control systems electrician, but not that it matters.)
It will work ok with it grounded to the chassis though. Just saying.
Originally Posted by Ahnold,Feb 23 2010, 07:48 PM
I think his point was that it's a waste of wire and time to run the ground up to the front of the car when it will work just as well to ground it to the body in the trunk. Actually, I'd bet it would be worse (marginally) to ground it to the block. The longer a length of wire is, the more resistance it will have.
Thanks for all the help guys..if FedEx gets that dropped off, I might start working on it this weekend..that is if the roads are nasty out...(cars currently in storage) have to drive it to the house.
Originally Posted by Irishflame27,Feb 24 2010, 11:16 AM
what kind of power are you looking for again?
I'll stop when I run out of pump.
Meaning I'll shoot for 600-700.
600whp on pump+meth
600whp+ on 110 +meth
We shall see.
*meth = 50/50 mix
