Most power on SC car
Old Jun 22, 2005 | 11:19 AM
BLOWNJROCK's Avatar
Originally Posted by nsxinsac,Jun 22 2005, 10:56 AM
I got 294.9whp with 179.9lbs torque with 9psi and all the mods you see below. It hits 9psi at about 8500rpm's and timing is almost maxed. Air/fuels are good. Not sure how people are getting 300+ whp.
huh, i'm getting those numbers at 5psi?
Old Jun 22, 2005 | 11:44 AM
OyATL's Avatar
Originally Posted by Silver S2k4,Jun 22 2005, 01:53 PM
How big is your 10lb pulley? I want to use the EMS to bump up my redline to 8,500 as well. You thinkg thats a good idea?
Mine is the 10lb. pulley from SOS, 3.5 inches I believe. Vtec is set at 4000 and my rev limit is set to 9300rpm. I don't ever take it to 9300 and just shift at 9000. Its just nice to have it set a little bit higher so I don't hit the rev limiter.
Old Jun 22, 2005 | 11:55 AM
Silver S2k4's Avatar
The thing is that with the 04 motors for it to make 10 pounds at 8k the pulley would have to be waaay smaller. This is why I would like to have it set at 8,500. Most of my power comes on at 7,000rpms, if I could keep it in the 7-8.5k range and make 10 psi by 8500 I think my car would run like butter.
Its just hard becuase I don't know of anyone who actually did any of this to the f22.
Old Jun 22, 2005 | 11:56 AM
bigpurp's Avatar
Originally Posted by Silver S2k4,Jun 22 2005, 01:58 PM
I am aiming for like 350 with the EMS and 8-9psi. You think its possible?
Yes, it is possible, as demonstrated by my old setup: https://www.s2ki.com/forums/index.php?showtopic=251463.
More than likely, you'll need to be on a first name basis with Joe, though.
Old Jun 22, 2005 | 12:15 PM
Whats the most anyone has on the Novi 1000 blower because I see everyone has the Vortech who goes for big HP.
Old Jun 22, 2005 | 12:16 PM
Originally Posted by OyATL,Jun 22 2005, 01:38 PM
Yes its possible. 3" single exhaust with no resonator and test pipe should help out alot but will be very LOUD! Mine was tuned conservatively on the rich side and I was able to get 350.
I'm stealing your boost is better badge
Old Jun 22, 2005 | 12:52 PM
Ztec's Avatar
The Novi 1000 maxes out impellar speed with a 3 inch pulley (where the belt rides) I bought mine from ASPRACING.COM and had it made out of steel on their advise (less slipping) Depending what your engine configuration is you can make anywhere from 13 to 18 pounds of boost with that pulley.
I will post a thread in the coming days when my motor arrives from Alaniz - I was told It shipped today
Old Jun 22, 2005 | 01:14 PM
SIIK2NR's Avatar
An I'm stealing it from you.....
Old Jun 22, 2005 | 01:18 PM
honda9krpm's Avatar
14psi with Vortech
I roughly double the stock power with a decompressed engine.
Old Jun 22, 2005 | 04:57 PM
joes sled 2000's Avatar
Not sure how people are getting 300+at the wheels??There is no magic with my setup!Its running stock boost,about 7.5 psi.I just gave it some more fuel. Its a vortech by the way.
