My SOT intake modification.
Old Apr 7, 2010 | 08:28 PM
ian02s2k's Avatar
Where are you located in St. Paul? Im in Woodbury, and would love to see this setup. Sorry, to thread jack.
Ian
Old Apr 8, 2010 | 06:31 AM
vader1's Avatar
Neptuner,
Do you have a thread about how you moved the fusebox without splicing? I would love to see it if you care to make one! There is a ton of space on the crossmember but I could not figure out how to get it there without splicing.
Ian,
I am probably about three miles from you in Cottage Grove. Send me a pm sometime after mid-may and you are welcome to take a look. My work schedule is too crazy between now and then and I will be working most nights and weekends until that time.
John
Old Apr 8, 2010 | 06:51 AM
camuman's Avatar
wait you moved it without splicing? damn i shoulda looked more at it before i just crammed a filter in there.
Old Apr 8, 2010 | 07:25 AM
vader1's Avatar
Oh c'mon Camuman, now you REALLY need to post pics! When you sent me the link to the filter you bought I thought "How the hell did he get this thing under the fusebox?" I wanna see!
Old Apr 8, 2010 | 02:04 PM
neptuner's Avatar
Originally Posted by vader1,Apr 8 2010, 08:31 AM
Neptuner,
Ian,
John
I did not cut the harness but I did extend it by about 2 feet. Not sure if this is considered a splice or not.
First I removed the OEM plastic harness connectors by slipping the harness terminals out of the plastic connectors. I acquired a spare fuse box harness, soldered on spade terminals and plugged the spare harness spade terminals into the OEM harness terminals. The spare harness has the proper plastic connectors to attach directly to the relocated fuse box.
The good part about extending the harness this way is all the wire colors and gages are correct in the extension. Also, all the soldering could be done on at a table instead of bending over the fender. If I ever want to go back to the stock fuse box location, no wire cutting or soldering will be needed.
MB
Dec 19, 2016 06:02 AM
jdm_Justin
Oct 25, 2012 10:54 AM
FlushAP1
Mar 16, 2012 07:54 AM
jkuamoo
Socal Swap Meet
18
Jul 9, 2009 02:28 AM
jkgoff2007
May 20, 2007 04:43 PM
