My Turbo/Motec Build
#172
I'm curious about the size selection. The R888R 305/35-18 is 26.5" tall. It also comes in a 315/30 that is 25.5" tall and a 335/30 that is 25.9" tall.
Why pick the narrower, taller tire?
Note: For reference, Robert Thorne's Big Bad Wolf S2000 uses the 315/30's in the front and the 335/30s in the rear.
#173
I can't wait!
The first time cutting was a major scare. It all comes easier after that lol.
I feel that the height will be more advantageous than the width gain of the 335's. I also didn't think I could fit the 335's with these overfenders and I didn't like the look of the other ones out there. After spacing the wheel out some with this setup I think there is a chance I could fit them though. I may entertain the 335's next time if these don't work as planned. I also plan to run a 26" slick here before too long and I figured if I could clear the fenders with these tires then the slicks should be fine as well.
#174
I can't wait!
#175
Again, I wanted to make sure I had tire clearance for a 26" tall slick, I feel the tire I went with is the best option for street and half stuff.
#176
That's a hell of a wide tire on there. Looks sick!
#178
Then this little guy showed up and I can’t ****ing wait to try it out. Should be a game changer on the track!
Quaife 69G Extreme Heavy Duty spur gear set. Geared to right at ~207mph in 6th for the 1/2 mile stuff.
#179
Is that wire for the level a pressure sensor? Will you be doing no-clutch WOT upshifts and no-clutch, no-throttle downshifts?
There was an interesting thread a few years back on straight cut vs. helical gears.
You are building one of the most impressive S2000s. Have you tried tuning with C85?
#180
